Wiring
Spirit can be used as a gyro, stabilisation and rescue system. Wiring to the unit depends on the type of receiver used.
Spirit is pre-programmed to 1520µs servo neutral impulse and 50Hz frequency – please ensure you have the correct servo parameters selected as specified by your servo manufacturer.
[hide]1 GYRO
R/C models can take advantage of the full capabilities of the Spirit unit. The Spirit will stabilize the model on all axes and also make it less affected by wind or other unfavorable conditions. When properly set up, flight characteristics should be more stable which will give you the confidence to carry out even the most challenging maneuvers.
Neverthless you can also completely disable the unit' operation so that the control will be same as without the system. Then it can be anytime re-enabled during the flight.
Spirit |
CH1 – 1st Aileron / Elevon servo |
CH2 – Elevator servo |
CH3 – 2nd Aileron / Elevon servo |
CH4 – Rudder servo |
Spirit Pro |
CH0 – Auxiliary (optional) servo |
Aileron servo on the model is mostly positioned on the right side while pitch on the left side.
2 CONNECTION OF STANDARD RECEIVER (PWM)
Spirit – receiver type: PWM
3 CONNECTION OF SPEKTRUM DSM2/X SATELLITE
4 CONNECTION OF FUTABA S-BUS RECEIVER
5 CONNECTION OF PPM RECEIVER
Spirit – receiver type: PPM
Connection to a BEC is optional. For models with standard size servos it is recommended to use dual power supply cables due to the increased power consumption. That means besides the communication cable, an additional power supply cable should be connected to the AUX port.
8 CONNECTOR ORIENTATION
