Zapojení
From Aero Manual
Revision as of 10:33, 6 October 2016 by Spiritdm (Talk | contribs) (Created page with "ZAPOJENÍ KLASICKÉHO PŘIJÍMAČE (s PWM modulací)")
Systém Spirit lze zapojit jako gyro, stabilizační a záchranný systém. Zapojení jednotky se odvíjí také od typu přijímače.
POZOR
Spirit je předprogramován na serva s neutrálním impulsem 1520μs a frekvencí 50Hz – prověřte typ všech serv a zjistěte parametry u výrobce.
Nikdy nepřipojujte propojky určené k napájení do pozice SYS a ELE/PIT/AIL!
1 GYRO
R/C models can take advantage of the full capabilities of the Spirit unit. The Spirit will stabilize the model on all axes and also make it less affected by wind or other unfavorable conditions. When properly set up, flight characteristics should be more stable which will give you the confidence to carry out even the most challenging maneuvers.
Neverthless you can also completely disable the unit' operation so that the control will be same as without the system. Then it can be anytime re-enabled during the flight.
CH1 – 1. servo křidélek/elevonu
CH2 – servo výškovky
CH3 – 2. servo křidélek/elevonu
CH4 – servo směrovky
Spirit Pro
CH0 – přídavné (volitelně) servo
POZNÁMKA
Samokřídla (Delta) mohou využít pro serva pouze výstupy CH1 a CH3.
2 ZAPOJENÍ KLASICKÉHO PŘIJÍMAČE (s PWM modulací)
Spirit – receiver type: PWM
Spirit Pro
3 CONNECTION OF SPEKTRUM DSM2/X SATELLITE
Spirit Pro
4 CONNECTION OF FUTABA S-BUS RECEIVER
Spirit Pro
5 CONNECTION OF PPM RECEIVER
Spirit – receiver type: PPM
Connection to a BEC is optional. For models with standard size servos it is recommended to use dual power supply cables due to the increased power consumption. That means besides the communication cable, an additional power supply cable should be connected to the AUX port.
Connection to a BEC is optional. For models with standard size servos it is recommended to use dual power supply cables due to the increased power consumption. That means besides the communication cable, an additional power supply cable should be connected to the AUX port. This protocol family can work with a wide range of receivers. Thus you can use Multiplex SRXL, BeastX SRXL, Graupner SUMD, Jeti UDI, Spektrum SRXL and more.
8 CONNECTOR ORIENTATION
