Jeti integration
From version 1.3.0 you can use the JETI integration with Spirit Aero! This mean you can fully configure Spirit units from JETI transmitters in real-time without need of a computer.
[hide]1 Requirements
- Jeti Duplex transmitter: DS/DS 14 or 16 or 24
- Jeti Duplex receiver with a free EX port.
- Jeti Integration cable available in our stores.
2 Wiring
The Jeti cable is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this cable.
- For new REX receivers the port label is E1 or E2 (EXT port will not work).
- For older EX receiver the port label is always EXT.
- To use UDI connection (SRXL/SUMD receiver type) - in this case you will loose the Jeti Integration.
- To buy a REX receiver where you can use a telemetry sensors and the Jeti integration together.
3 Spirit Aero software
Now you are ready to power up the unit. If your Power supply is not connected yet, we recommend to connect it to the AUX1, AUX2 and/or CH0 port or receiver port. Before you can utilize the Jeti Integration and EX Bus connection, it is important to set the EX Bus receiver type in the General tab of the software. Please start the Spirit Aero software and change the receiver type as displayed on the photo. Then save the settings (e.g. by CTRL+S) or the Backup tab/Unit - Save and restart the unit.
4 Integration Menu
5 Usage
Whenever you want to configure a parameter, go to the Applications/Jetibox/Mx. There the Menu Layout is nearly identical with the PC software to have easy navigation.
When using Bank Switching or Real-Time tuning features the menu will take full control of it. The unit will not react to a Switch position changes. For the Bank Switching there is a menu Bank in the main menu where you can manually change the banks.
Always close the integration menu with long press of Up arrow button. Otherwise Bank Switching or Real-Time tuning features will be temporarily disabled. When closed correctly, the unit's Status LED will be steady on.
Do not forget to click the Save Settings in the integration menu when you want to save a changes permanently.
6 Preset for transmitter
The profile has enabled:
- Flight modes
- Bank Switching
- Rescue/Stabilisation modes (activated by a Separate channel)
In your transmitter there will be new profile called Spirit Aero that you can select.
7 Channel Mapping
Channel Layout:
- Throttle
- Aileron
- Elevator
- Flaps
- Rudder
- Gyro sens.
- Bank (if used)
- Stabi (if used)
8 Telemetry data
- S Vibes [%] - Vibration level from all axes (0 - 10% is normal level)
- S RPM [RPM] - ESC Telemetry (Heli) | Rotor revolutions.
- S Voltage [V] - ESC Telemetry (Heli) | Main Battery voltage
- S Current [A] - ESC Telemetry (Heli) | Main Battery current
- S Capacity [mAh] - ESC Telemetry (Heli) | Main Battery consumed capacity
- S Temp [°C] - ESC Telemetry (Heli) | FET temperature
