ESC telemetry
From Aero Manual
Revision as of 15:51, 15 November 2017 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
The ESC telemetry is feature that allows you to display data from your Electronic Speed Controller (ESC) directly in the transmitter. Depending on transmitter capabilities you can Log the values and use them for a various purposes.
The ESC telemetry is mediated through the Spirit units (Aero firmware v1.2+) as these are able to read the data and communicate with both receiver and ESC at the same time.
1 List of supported Radios
Info.png These radios support full integration/telemetry as well.
2 List of supported ESCs
3 Interfacing
4 Telemetry data
Spirit firmware v1.3 supports up to 7 telemetry variables displayed at the single time. Future updates will extend such possibilities.
  • Battery Voltage [V]
  • Battery Current [A]
  • Motor Speed [RPM] - Revolutions of propeller.
