ESC Telemetrie
The ESC telemetry is feature that allows you to display data from your Electronic Speed Controller (ESC) directly in the transmitter. Depending on transmitter capabilities you can Log the values and use them for a various purposes.
The ESC telemetry is mediated through the Spirit units (Aero firmware v1.2+) as these are able to read the data and communicate with both receiver and ESC at the same time.
1 List of supported Radios
2 List of supported ESCs
- Castle Creations Phoenix & Talon (Heli)
- HobbyWing Platinum V4 (Heli)
- Scorpion Tribunus (Heli)
- Kontronik KOSMIK & JIVE PRO (Heli)
- Kontronik JIVE (Heli)
3 Interfacing
4 Telemetry data
Spirit firmware v1.3 supports up to 7 telemetry variables displayed at the single time. Future updates will extend such possibilities.
- Battery Voltage [V]
- Battery Current [A]
- BEC Voltage [V] - provided by ESC Telemetry or Receiver.
- Consumed Capacity [mAh] - Battery Capacity consumed from the initialization point.
- ESC Temperature [°C] - Usually temperature of the FET transistors.
- Motor Speed [RPM] - Revolutions of propeller.
- Vibration Level [%] - provided by unit itself. (also with ESC Telemetry disabled)
