Wiring
From Aero Manual
Revision as of 13:56, 19 March 2025 by ZeXx86 (Talk | contribs)
Spirit can be used as a gyro, stabilisation and rescue system. Wiring to the unit depends on the type of receiver used.
Warning.png Spirit is pre-programmed to 1520µs servo neutral impulse and 50Hz frequency – please ensure you have the correct servo parameters selected as specified by your servo manufacturer.
1 GYRO
R/C models can take advantage of the full capabilities of the Spirit unit. The Spirit will stabilize the model on all axes and also make it less affected by wind or other unfavorable conditions. When properly set up, flight characteristics should be more stable which will give you the confidence to carry out even the most challenging maneuvers.
Neverthless you can also completely disable the unit' operation so that the control will be same as without the system. Then it can be anytime re-enabled during the flight.
2 SERVO CONNECTION
CH1 – 1st Aileron / Elevon servo
CH2 – Elevator servo
CH3 – 2nd Aileron / Elevon servo
CH4 – Rudder servo
CH0 – 2nd Elevator (optional) servo
AUX2 (AUX for Spirit RS, GTR, W1) – 2nd Rudder (optional) servo
AUX (THR for Spirit RS, GTR, W1) – Throttle Output - ESC or Throttle Servo
Info.png Flying wing (Delta) models should use only CH1 and CH3 servo outputs.
3 RECEIVER CONNECTION
Receiver wiring is described at this page: https://manual.spirit-system.com/index.php?title=Wiring
All schematics can be found also at the Spirit Settings PC software - Setup Wizard.
4 CONNECTOR ORIENTATION
4.1 μSpirit
Warning.png Pin layout of the JST-ZH(R) connectors is different from standard Servo connectors. BROWN (Middle) wire is GND pin. ORANGE wire is SIGNAL pin. RED wire is +5V (BEC voltage). By using JST-Servo cables you can connect a classic Servos and all Spirit peripherals to the μSpirit even with Servo connectors.
4.2 Spirit and Spirit Pro
