Translations:Configuration/414/en
From Aero Manual
Revision as of 12:17, 5 December 2016 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
To verify that the Rescue mode is operating properly, you can activate the Rescue and observe the elevator. When the model is lying with e.g. gears on the ground, elevator should go always up (if the Rescue inclination is configured to a non zero value). When you tilt the model (nose up), the elevator must return back as the model will achieve a configured inclination.
