Režimy Stabi
From Aero Manual
Revision as of 12:19, 3 March 2017 by Spiritdm (Talk | contribs) (Created page with "Zisk ve vysílači (nejčastější volba)")
Od verze 1.1. je možné pro aktivaci režimu Stabi/Funkce použít:
  • Záporný obecný zisk
  • Vybraný kanál (NOVÉ)
1 Záporný obecný zisk
Info.png Obecný zisk stále plní funkci zisku gyra pro všechny osy, ale zároveň, podle toho, zda je kladná či záporná, může zvolenou funkci vypnout či zapnout. Tzn. je důležité nastavit hodnotu zisku správně pro oba režimy - letový režim i vybranou funkci. Běžně jsou hodnoty stejné, ale s opačným znaménkem (např. +60%/-60%).
This is the common way how pilots are configuring the Global Gain. It can be easily programmed for a two-state switch. For the Rescue a momentary switch is the best. Usually you can find the configuration in the GYRO menu in your transmitter. For the beginning you can set:
  • Position 0: 40% (flight with Head-Lock enabled)
  • Position 1: -40% (selected function)
This will set a moderate Global Gain and allow to select which mode will be used anytime during the flight.
Do not forget to set the gains accordingly for your model. Also make sure that the Global Gain function is assigned in the software.
1.2 In the software
When you do not want to or can't set your Global Gain in the transmitter, you can do so in the software. There is only requirement to unassign the Global Gain function in the General/Channels window. This mean that transmitter have no control over the Global Gain. Instead the value is configured by the Sensor/Global Gain parameter.
There is disadvantage that in order to activate selected function, you have to set a negative Global Gain. This can't be changed during the flight normally. On the other hand, you can use a Bank Switching feature and program a different Function and Global Gain for each bank.
1. First step
2. Second step
1.3 Function vs Gyro
Following table is describing how Global Gain can activate selected Function.
Function Global gain Gyro mode Mode
Disabled 0 - 100% Head-Lock -
2 Separate channel
Channel configuration
  1. Open the General/Channels.
Function indicator
  • 0 - function is inactive.
  • 1 - function is active.
Info.png Global Gain can still change gyro mode (Head-Lock or Normal).
2.1 Function vs Channel
Function Channel Mode
Disabled 0 - 100% -
Rescue (Normal) 0 - 100% -
Rescue (Acro) 0 - 100% -
Disabled -100% - 0% -
2.2 Function vs Gyro
