Translations:Wiring/71/en
From Aero Manual
Revision as of 03:56, 11 March 2017 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
Connection to a BEC is optional. For models with standard size servos it is recommended to use dual power supply cables due to the increased power consumption. That means besides the communication cable, an additional power supply cable should be connected to the AUX port. This protocol family can work with a wide range of receivers. Thus you can use Multiplex SRXL, BeastX SRXL, Graupner SUMD, Jeti UDI, Spektrum SRXL and more.
