Stabilizace (Akro)
From Aero Manual
Revision as of 10:57, 7 April 2017 by Spiritdm (Talk | contribs) (Created page with "Stabilizační režim je funkce jednotky, která pomáhá pilotovi udržovat model v rovině. Model je plně pod kontrolou pilota, ale na rozdíl od běžného režimu letu m...")
Stabilizační režim je funkce jednotky, která pomáhá pilotovi udržovat model v rovině. Model je plně pod kontrolou pilota, ale na rozdíl od běžného režimu letu má tendenci vracet se automaticky do horizontu
You can activate the mode remotely by assigned switch of your transmitter. As long as the switch is in active position, the stabilisation mode will be engaged. Otherwise normal flight mode will be used.
1 Characteristics
  • Upon activation of the Stabilisation (Acro), the model will attain horizontal level rather slowly (landing gears down or up depending on what is closer).
  • It is perfect for learning basic acrobatics maneuvers.
  • In this mode it is possible perform a flips or rolls as you are used to do from normal flight mode.
  • As soon as the sticks are released, the model will return to the horizontal position (one which is closer).
  • Throttle is controlled by the pilot as in a normal flight mode.
Info.png For rescue of the model we highly recommend to use the Rescue mode instead of stabilisation.
2 Setttings
To make it comfortable for your needs you can set the Direction control rate parameter. This will affect how fast the model will return to the horizontal position when stick(s) are released.
  • Low values are recommended for beginners - it will return faster to the horizontal position.
  • Higher values will return the model slowly and will make it closer to a normal flight mode.
