Wiring
From Aero Manual
Revision as of 06:46, 19 July 2017 by Spiritdm (Talk | contribs)
Spirit can be used as a gyro, stabilisation and rescue system. Wiring to the unit depends on the type of receiver used.
Warning.png Spirit is pre-programmed to 1520µs servo neutral impulse and 50Hz frequency – please ensure you have the correct servo parameters selected as specified by your servo manufacturer.
1 GYRO
R/C models can take advantage of the full capabilities of the Spirit unit. The Spirit will stabilize the model on all axes and also make it less affected by wind or other unfavorable conditions. When properly set up, flight characteristics should be more stable which will give you the confidence to carry out even the most challenging maneuvers.
Neverthless you can also completely disable the unit' operation so that the control will be same as without the system. Then it can be anytime re-enabled during the flight.
CH1 – 1st Aileron / Elevon servo
CH2 – Elevator servo
CH3 – 2nd Aileron / Elevon servo
CH4 – Rudder servo
Spirit Pro
CH4 – Rudder servo
CH0 – Auxiliary/2nd Elevator (optional) servo
Info.png Flying wing (Delta) models should use only CH1 and CH3 servo outputs.
2 CONNECTION OF STANDARD RECEIVER (PWM)
Spirit – receiver type: PWM
The easiest way you can start is to connect RUD with Rudder output in the receiver. Then continue with AUX which should be connected to the Gyro Gain channel output. Next, connect the Aileron (AIL pin), Elevator (ELE pin) channels and optionally Flaps channel (PIT pin). If you are not sure whether you have the correct output or not, you can plug in one servo and power the unit to verify that your connection is correct. This can be repeated for each servo. The diagnostics tab is very helpful too.
Spirit Pro
3 CONNECTION OF SPEKTRUM DSM2/X SATELLITE
Spirit Pro
4 CONNECTION OF FUTABA S-BUS RECEIVER
Spirit Pro
5 CONNECTION OF PPM RECEIVER
Spirit – receiver type: PPM
Info.png Connection to a BEC is optional. For models with standard size servos it is recommended to use dual power supply cables due to the increased power consumption. That means besides the communication cable, an additional power supply cable should be connected to the AUX port.
Info.png Connection to a BEC is optional. For models with standard size servos it is recommended to use dual power supply cables due to the increased power consumption. That means besides the EX Bus cable, an additional power supply cable should be connected to the AUX port.
Info.png Connection to a BEC is optional. For models with standard size servos it is recommended to use dual power supply cables due to the increased power consumption. That means besides the communication cable, an additional power supply cable should be connected to the AUX port. This protocol family can work with a wide range of receivers. Thus you can use Multiplex SRXL, BeastX SRXL, Graupner SUMD, Jeti UDI, Spektrum SRXL and more.
8 CONNECTOR ORIENTATION
8.1 μSpirit
Warning.png Pin layout of the JST-ZH(R) connectors is different from standard Servo connectors. BROWN (Middle) wire is GND pin. ORANGE wire is SIGNAL pin. RED wire is +5V (BEC voltage). By using JST-Servo cables you can connect a classic Servos and all Spirit peripherals to the μSpirit even with Servo connectors.
8.2 Spirit and Spirit Pro
