Jeti Integration
From Aero Manual
Revision as of 14:16, 17 November 2017 by Admin (Talk | contribs) (Created page with "Auf der Empfängerseite muss das Servokabel an den EX-Busanschluss angeschlossen werden.")
Ab Version 1.3.0 können Sie die JETI-Integration nutzen! Das bedeutet, Sie können Spirit-Geräte völlig mit JETI-Sendern in Echtzeit konfigurieren, ohne dass ein Computer benötigt wird.
1 Voraussetzungen
  • Jeti Duplex Sender: DC/DS 14 or 16 or 24
  • Jeti Duplex-Empfänger mit einem freien EX-Port
  • Jeti Integrationskabel in unseren Filialen erhältlich.
2 Verkabelung
  • For new REX receivers the port label is E1 or E2 (EXT port will not work).
  • For older EX receiver the port label is always EXT.
  • To use UDI connection (SRXL/SUMD receiver type) - in this case you will loose the Jeti Integration.
  • To buy a REX receiver where you can use a telemetry sensors and the Jeti integration together.
3 Spirit Aero software
Now you are ready to power up the unit. If your Power supply is not connected yet, we recommend to connect it to the AUX1, AUX2 and/or CH0 port or receiver port. Before you can utilize the Jeti Integration and EX Bus connection, it is important to set the EX Bus receiver type in the General tab of the software. Please start the Spirit Aero software and change the receiver type as displayed on the photo. Then save the settings (e.g. by CTRL+S) or the Backup tab/Unit - Save and restart the unit.
4 Integration Menu
4.1 Integration menu still unavailable
5 Usage
Whenever you want to configure a parameter, go to the Applications/Jetibox/Mx. There the Menu Layout is nearly identical with the PC software to have easy navigation.
When using Bank Switching or Real-Time tuning features the menu will take full control of it. The unit will not react to a Switch position changes. For the Bank Switching there is a menu Bank in the main menu where you can manually change the banks.
Always close the integration menu with long press of Up arrow button. Otherwise Bank Switching or Real-Time tuning features will be temporarily disabled. When closed correctly, the unit's Status LED will be steady on.
Do not forget to click the Save Settings in the integration menu when you want to save a changes permanently.
6 Preset for transmitter
The profile has enabled:
  • Flight modes
  • Bank Switching
In your transmitter there will be new profile called Spirit Aero that you can select.
7 Channel Mapping
Channel Layout:
  1. Throttle
  2. Aileron
  3. Elevator
  4. Flaps
  5. Rudder
  6. Gyro sens.
  7. Bank (if used)
  8. Stabi (if used)
8 Telemetry data
  • S RPM [RPM] - ESC Telemetry | Rotor revolutions.
