First flight
From Aero Manual
Revision as of 10:15, 6 October 2016 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
If you are sure that the unit is correctly configured, you are ready for your first flight.
1 PRE-FLIGHT CONTROL
  1. Turn on the transmitter and connect the battery to the model.
  2. Wait for the initialization, until the control elements will signalize the event.
  3. Tilt the model, ensure the control emements are compensating in the correct direction on all axes. In other words, movement to a certain direction will result in movement of the control element (it's end) in the same direction.
  4. Check that input from the transmitter sticks is moving with the control elements in a proper directions.
WARNING
If you encounter a problem or something appears wrong at this point, do not try to take off!
2 TAKEOFF
  1. Set the Gyro Gain to value of 40% for the first flight. This will set the Head Lock mode at a moderate activity for all 3-axes.
  2. Spool up the motor to a desired speed.
  3. Take off as you are used to.
  4. In any time, you can switch the Gyro Gain to 0% which will deactivate the Gyro operation if needed.
