Translations:Configuration/140/en
From Aero Manual
Revision as of 12:03, 6 October 2016 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
Some servo reached its configured limit. When this event occurs before or after a flight it is not a problem. If you see this during flight it indicates that the model achieved it's maximum configured deflection for the control elements/servos. Usually it is not an issue, but if you will notice that the model is unable to rotate fast enough, then the configured range in the Servo tab is too small.
