Translations:Configuration/248/en
From Aero Manual
Revision as of 08:13, 7 October 2016 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
This parameter is used to set amount of direct feel between your sticks and your model. The higher the value, the more aggressive the model will feel and the faster the model will react to the stick movements. If the value is very high, bounce-back effect can occur when a stick is released quickly. It will also affect rotation speed in all axes similarly to Dual Rate. If the model feels disconnected and there is a lag between stick inputs and the model, try increasing this value.
