Problémy a jejich řešení
From Aero Manual
Revision as of 08:20, 7 October 2016 by Spiritdm (Talk | contribs) (Created page with "Rotace modelu je příliš malá/velká")
| Popis problému | Řešení |
| Aileron, elevator or rudder drifts after initialization | Check trims and subtrims. Sticks in neutral position must be 0%, see the Diagnostics tab. Increase Stick deadband in the Advanced tab. |
| Řízení modelu není precizní | Přidejte v záložce Senzor zisk senzoru a/nebo zvyšte zisk gyra ve vysílači. Přidejte exponenciální výchylky ve vysílači. |
| Model osciluje přes osu křidélek, výškovky či směrovky | Uberte zisk senzoru pro příslušnou osu v záložce Senzor postupně po pěti, dokud problém nezmizí. Zkontrolujte, zda je chod mechaniky dostatečně hladký. |
| Rotace modelu je příliš malá/velká | Increase/decrease Dual Rate for rudder in your transmitter. Or increase/decrease Feed forward value in the Advanced tab. |
| Servos jitter randomly without external influences | Check the cable connection between the receiver and the unit. |
| Aggressive stick movement leads to a bouncing | Decrease Feed forward in the Advanced tab or decrease Sensor gain for the affeced axis in the Sensor tab. |
| Stick input response is delayed or steering is disconnected | Increase Feed forward in the Advanced tab. |
| Initialization finished notification was changed | Flight log from the previous flight was saved. View the log in the Diagnostic tab and fix reported problem. |
| Control elements are jumping in a cycle when initialization is finished | The unit was started with the Rescue mode engaged. Turn off the rescue from your transmitter. |
