Stabi mode
In order to enable rescue or stabilisation modes you have to set Stabi/Function to a desired option. When Disabled, no special function will be used.
From version 1.1. it is possible to activate the Stabi/Function in the two ways:
- Negative Global Gain
- Separate channel (NEW)
1 Negative Global Gain
For normal flying a positive Global Gain is used. To activate function which is selected in the parameter Stabi/Function it is necessary to set a negative gyro gain.
Global Gain is still used to set the gyro gain for all axes. At the same time, positive or negative value will determine if selected function is inactive or active. So it is important to set the gyro gain properly for both normal flight and selected function. Usually same, but opposite values are fine (for example +40%/-40%)
The function is active as long as the Global Gain is negative. Then the Head-Lock for all axes is engaged again. Because unit allow to set the Global Gain by your transmitter or directly in the software, you have two options how to do that.
This is the common way how pilots are configuring the Global Gain. It can be easily programmed for a two-state switch. For the Rescue a momentary switch is the best. Usually you can find the configuration in the GYRO menu in your transmitter. For the beginning you can set:
- Position 0: 40% (flight with Head-Lock enabled)
- Position 1: -40% (selected function)
This will set a moderate Global Gain and allow to select which mode will be used anytime during the flight.
Do not forget to set the gains accordingly for your model. Also make sure that the Global Gain function is assigned in the software.
1.2 In the software
When you do not want to or can't set your Global Gain in the transmitter, you can do so in the software. There is only requirement to unassign the Global Gain function in the General/Channels window. This mean that transmitter have no control over the Global Gain. Instead the value is configured by the Sensor/Global Gain parameter.
There is disadvantage that in order to activate selected function, you have to set a negative Global Gain. This can't be changed during the flight normally. On the other hand, you can use a Bank Switching feature and program a different Function and Global Gain for each bank.
1.3 Function vs Gyro
Following table is describing how Global Gain can activate selected Function.
Function | Global gain | Gyro mode | Mode |
Disabled | 0 - 100% | Head-Lock | - |
Rescue (Normal) | 0 - 100% | Head-Lock | - |
Rescue (Acro) | 0 - 100% | Head-Lock | - |
Stabilisation (Normal) | 0 - 100% | Head-Lock | - |
Stabilisation (Acro) | 0 - 100% | Head-Lock | - |
Disabled | -100% - 0% | Normal (Rate) | - |
Rescue (Normal) | -100% - 0% | Head-Lock | Rescue |
Rescue (Acro) | -100% - 0% | Head-Lock | Rescue |
Stabilisation (Normal) | -100% - 0% | Head-Lock | Stabilisation |
Stabilisation (Acro) | -100% - 0% | Head-Lock | Stabilisation |
2 Separate channel
- Channel configuration
- Open the General/Channels.
- Function indicator
- 0 - function is inactive.
- 1 - function is active.
Global Gain can still change gyro mode (Head-Lock or Normal).
2.1 Function vs Channel
Function | Channel | Mode |
Disabled | 0 - 100% | - |
Rescue (Normal) | 0 - 100% | - |
Rescue (Acro) | 0 - 100% | - |
Stabilisation (Normal) | 0 - 100% | - |
Stabilisation (Acro) | 0 - 100% | - |
Disabled | -100% - 0% | - |
Rescue (Normal) | -100% - 0% | Rescue |
Rescue (Acro) | -100% - 0% | Rescue |
Stabilisation (Normal) | -100% - 0% | Stabilisation |
Stabilisation (Acro) | -100% - 0% | Stabilisation |
2.2 Function vs Gyro
