Nastavení
From Aero Manual
Revision as of 12:47, 6 October 2016 by Spiritdm (Talk | contribs) (Created page with "INSTALACE KONFIGURAČNÍHO SOFTWARE")
1 PROPOJENÍ S POČÍTAČEM
Není nutné nic doinstalovat.
Program Spirit Aero lze spojit s jednotkou také pomocí Wifi modulu. Jedná se o tzv. Spirit Wifi-Link. Odpadne tak nutnost používat USB interface a konfiguraci je možné provádět bezdrátově. Jak modul připojit a nastavit je popsáno v jeho příručce, kterou lze stáhnout zde
2 PROPOJENÍ S JEDNOTKOU
Below are the installation instructions for the supported platforms. The configuration software is available on the Spirit System website:aero.spirit-system.com/.
Run the installer and follow the wizard. If the driver is not installed yet, you will be given the option to do so during the installation process. The installer will go through all the necessary steps to prepare your computer for running the configuration software. Upon completion of the installation process, the configuration software can be launched from your desktop or program list, called “Spirit Aero”.
Install the downloaded software by opening the DMG file and then moving the content to your Applications folder. Configuration software can be launched from the Applications folder with “Spirit-Aero“.
4 CONFIGURATION SOFTWARE
Start the Spirit Aero from your desktop or a directory where it was installed.
The configuration software should be started after the unit has initialized. Whenever the Spirit is initialized (status LED is on) and connected, you can make adjustments to the settings. Configuration during flight is not possible due to the associated safety risks.
PROBLEMS WITH WINDOWS
5 SOFTWARE USAGE
After successful connection of the Spirit unit, all configuration features should be accessible. If not, try to either choose another COM port (Device) or try to restart the software, disconnecting the unit from the power supply and repeating the procedure.
5.1 CONNECTION TAB
Select the model type. In case that the model is equipped with 3-4 servos, please select Plane. For Flying Wing (Delta), please select Flying Wing.
PWM – standard receiver.
PPM – single line connection.
Channels
When a channel for Global Gain function is unassigned, it is possible to configure global gain directly through this software in Sensor tab. The unassigned channel could be used in another way, e.g. for Bank switching.
Secondly it is necessary to check the values of aileron, elevator, pitch and rudder channels. These channels must be centered at approximately 0%. The unit automatically detects the neutral position during each initialization. Do not use subtrim or trim functions on your transmitter for these channels, as the Spirit unit will consider these as an input command.
  • N – Normal (Rate)
  • HL – Head Lock (will hold direction)
SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
Vibrations are transmitted to each axes dependent on several, various factors. Frequencies and magnitude are dependent on the model construction. Generally, the vibrations are the highest on Y axis (aileron) but we recommend you check all axes each time you are doing measurement. However vibrations should not exceed 50% for all axes at any time. In the case vibrations are at 90% or more, the model has an issue that needs to be rectified. Should the magnitude exceed 90% on any of the given axes, it is recommended to fix whatever issue is causing these extreme vibrations before flying the model. Even though Spirit unit is highly resistant to vibrations, these could cause unwanted interactions with the Spirit unit and could also cause mechanical failure of the model. Such high vibrations can cause Loctite to fail and other mechanical parts to break.
  1. Remove a propellers from the model or block it from movement.
  2. Place the model on a suitable, soft surface (e.g. grass).
  3. Run the Spectrum analyser (this also freezes all servos).
  4. Spin up the motor to the usual flight RPM.
  5. Switch between the X, Y and Z axes, saving an image of each.
  6. Check vibrations in all axes.
  7. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
Zv.png Aileron, Elevator, Rudder Limit Reached:
Some servo reached its configured limit. When this event occurs before or after a flight it is not a problem. If you see this during flight it indicates that the model achieved it's maximum configured deflection for the control elements/servos. Usually it is not an issue, but if you will notice that the model is unable to rotate fast enough, then the configured range in the Servo tab is too small.
Tr.png Receiver Signal Lost:
Signal lost suddenly. This problem should not occur at any time and must be resolved before the next flight. There could be a problem with the receiver and/or transmitter antennas. It could be a faulty receiver cable or the connection between the unit and receiver. In some cases signal loss can happen because of interference that is coming from a radio tower.
Tr.png Power Voltage is low:
Vibration level achieved the level that is not normal and can affect integrity of the model. During hard acrobatic maneuvers the event can occur more frequently.
By ticking the item Subtrim (tuning) the unit will be switched into a special mode where you can set the servo neutral position. In addition, gyro will be disabled. Servos can easily be adjusted at this time, e.g. by arrows.
In most cases, it is also necessary for servo arms to be perpendicular to the main shaft. All servos, i.e., CH1, CH2, CH3 and CH4, are set separately on individual sliders. CH1 and CH3 are the aileron servos. CH2 controls the elevator and CH4 controls the rudder.
After exiting the special mode, gyro will work again.
Servo reverse
This allows you to choose which servos should have their direction of motion reversed. After this settings the model should react correctly to the sticks movement. This parameter is the most important!
Sets the minimum and maximum deflection of the servos. We recommend setting these values for both directions to the maximum allowed range by the manufacturer of the model. If range is too small, it will not allow you to perform fast rotations.
Global Gain – This parameter is enabled only in case of unassigned Gyro gain channel. It replaces function of Gyro gain from the transmitter, so you can directly set the value in the software.
Sensor Gain
  • Head-Lock mode: 1% to 100%
WARNING
Rescue inclination
This determines inclination of the model that will be maintained during rescue activation. 100% means the maximum inclination (angle) of the model. With 0% model will recover to the horizontal position.
This specifies the rate of controlling direction for the stabilization mode. Low values are well suited for beginners. Higher values are more appropriate for Acrobatics learning.
Feed forward
This parameter is used to set amount of direct feel between your sticks and your model. The higher the value, the more aggressive the model will feel and the faster the model will react to the stick movements. If the value is very high, bounce-back effect can occur when a stick is released quickly. It will also affect rotation speed in all axes similarly to Dual Rate. If the model feels disconnected and there is a lag between stick inputs and the model, try increasing this value.
Aileron Differential
7 SOFTWARE KEYBOARD CONTROL
